11 years agoInconsistency detected by ld.so: dl-close.c: 764: _dl_close: Assertion `map->l_init_c
I keep getting this message whenever I run Quartus (15.0) on most non-supported Linux distributions. The message does not seem to be fatal, but some tools/scripts will check the output of Quartus and...
9 years agoI had same problem.
wbgreen's solution seemed to be correct answer. but, it didn't work. so, I restored .bak files one by one except 'libccl_curl_drl.so.bak' I don't know why, Quartus Prime goes well. Anyone knows about this?
