16 years agoIncluding QIP from custum_ip_hw.TCL
I have got to get rid of any absolute path and change it to relative path.
so i went through all my custom sopc components i did and added a QIP that should add all those files *.v *.mif ... this sopc component needs. such a QIP looks like --- Quote Start --- set_global_assignment -name SEARCH_PATH [file join $::quartus(qip_path) "." ] set_global_assignment -name MISC_FILE [file join $::quartus(qip_path) Sopc_Uart_Fifo_Register.qip ] set_global_assignment -name MISC_FILE [file join $::quartus(qip_path) Sopc_Uart_Fifo_M4K.qip ] set_global_assignment -name MISC_FILE [file join $::quartus(qip_path) Sopc_Uart_Fifo_M9K.qip ] set_global_assignment -name VERILOG_FILE [file join $::quartus(qip_path) "Sopc_Uart_RxFifo.v"] set_global_assignment -name VERILOG_FILE [file join $::quartus(qip_path) "Sopc_Uart_TxFifo.v"] set_global_assignment -name VERILOG_FILE [file join $::quartus(qip_path) "sopc_uart_rxd.v"] set_global_assignment -name VERILOG_FILE [file join $::quartus(qip_path) "sopc_uart_txd.v"] --- Quote End --- now i would like to setup quartus / sopc in a way that whenever such a custom component is included all QIPs for this component are used. with the sopc component editor i had included the qip file, but it is not used /added so i added this file manualy into the quartus project settings dialog (what is not what i want, as this is not automatically) now quartus lists only my 4 verilog *.v, but none of the files from the QIP that are listed inside my QIP question, does anybody know how i must setup my custom component (via TCL?) that all QIP and SDC are included and used without manualy adding them to the project whenever such a custom ip is used ???? thanks in advance.
