IDENTIFYING THE ECC BYTE IN 40 bit DATA BUS OF EMIF CONTROLLER of ARRIA 10 HPS
Hi MHada,
DQ0 - DQ31 is Data pin, DQ32 - DQ39 is ECC pin.
The ECC pin should be placed in Lane 3 of IO Bank 2K as mentioned in the User Guide.
You can swap the pin placement in the Quartus and place the DQ32 - DQ39 in Bank 2K.
Adzim
- MHada1 year ago
Hi Adzim,
Thanks for the prompt reply.
Very sorry it got missed !! I am still under confusion on this.
When you talk about DQ0 - DQ31, are you talking about the controller signal name on Quartus or the data bus assigned on my schematic.
I find the DQ0 to DQ7 assigned to lane 3 in bank 2K and the project getting compiled in 32 bit data + ECC DDR4 configuration !!
Quartus should not compile the project if that is the case. I seriously think I am doing something wrong here !!
I will follow this closely.
- MHada1 year ago
Hi, @AdzimZM_Intel
I forgot to tell that I have attached my schematic and pin config files in previous post.
Pls help us in this !!
