10 years ago
Identifier "UNSIGNED" is not directly visible
i have used the following libaries
LIBRARY IEEE;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
USE ieee.numeric_std.all;
still the error in modelsim shows :
** Error: G:/vhdl code/vhdl code/dwt_main.vhd(30): (vcom-1078) Identifier "UNSIGNED" is not directly visible.
Potentially visible declarations are:
ieee.NUMERIC_STD.UNSIGNED (subtype declaration)
ieee.std_logic_arith.UNSIGNED (type declaration)
** Error: G:/vhdl code/vhdl code/dwt_main.vhd(31): (vcom-1078) Identifier "SIGNED" is not directly visible.
ieee.NUMERIC_STD.SIGNED (subtype declaration)
ieee.std_logic_arith.SIGNED (type declaration)
how to solve it
    Curious, what did you write for dwt_main.vhd line 30 and 31?
    line 30 TYPE buf_ary IS ARRAY(NATURAL RANGE <>) OF UNSIGNED(7 DOWNTO 0);
    line 31 TYPE buf_ary_d IS ARRAY (NATURAL RANGE <>) OF SIGNED(7 DOWNTO 0);
    Try leaving out:
    It is a deprecated library, you will find everything you need in:
    i have already included these libraries above
    LIBRARY IEEE;
    Try just the following:
    library ieee ;
    use ieee.std_logic_1164.all ;
    use iee.numeric_std.all;
    yes it worked ....for the time being that error got solved.....thanks
    The error is caused by numeric_std and std_logic_arith both declaring the unsigned and signed types, meaning you need to specifically state which one to use:
    eg.
    signal a : numeric_std.unsigned;
    signal b : std_logic_arith.unsigned;
    The problem is they are not the same type, and VHDL rules mean that two types with the same name in the same namespace become invisible.
    std_logic_arith is not a standard VHDL library - and so should not be used.
