10 years agoIdentifier "UNSIGNED" is not directly visible
i have used the following libaries LIBRARY IEEE; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; USE ieee.numeric_std.all; still the error in modelsim shows : ...
10 years agoThe error is caused by numeric_std and std_logic_arith both declaring the unsigned and signed types, meaning you need to specifically state which one to use:
eg. signal a : numeric_std.unsigned; signal b : std_logic_arith.unsigned; The problem is they are not the same type, and VHDL rules mean that two types with the same name in the same namespace become invisible. std_logic_arith is not a standard VHDL library - and so should not be used.
