10 years agoIdentifier "UNSIGNED" is not directly visible
i have used the following libaries LIBRARY IEEE; USE ieee.std_logic_1164.all; USE ieee.std_logic_arith.all; USE ieee.numeric_std.all; still the error in modelsim shows : ...
10 years agoTry leaving out:
It is a deprecated library, you will find everything you need in: USE ieee.numeric_std.all;
