11 years ago
I have the problem that my RS232 always is sending data to the PC
Dear readers - I have been programming following code:
//****** PAVLE DUKANOVIC *******
//****** www.dukelanovic.com *******
//****** [email protected] *******
// Serial port demo program
// http://www.techques.com/question/4-13718/implement-serial-port-on-fpga-(verilog)
// Assumptions: 50Mhz clock rate
module serial(input clk,input key_in, output ser, input rxd);
// Start signal tells it to start sending bits
reg[24:0]count;
reg [3:0] ones;
reg [3:0] tens;
//The bits of data to send
reg [7:0] data;
reg sec;
reg [14:0] clockdiv;
reg [14:0] clockdivrx;
// Output register to pin
assign ser = outbit;
// Count from 0..5207 then reset back to zero (9600 Baud for TX)
always @(posedge clk)
begin
if (clockdiv == 5207)
clockdiv <= 0;
else
clockdiv <= clockdiv + 1;
end
begin
if (clockdivrx == 1302)
clockdivrx <= 0;
else
clockdivrx <= clockdivrx + 1;
end
// The serclock is a short pulse each time we are reset
wire serclock = (clockdiv == 0);
wire start = (clockdiv == 0);
wire serclockrx = (clockdivrx == 0);
// Serial port state machine
// Only start the state machine when "start" is set. Only advance to the
// next state when serclock is set.
reg [3:0] state;
begin
case (state)
4'b0000: if (start) state <= 4'b0001;
4'b0001: if (serclock) state <= 4'b0010; // Start bit
4'b0010: if (serclock) state <= 4'b0011; // Bit 0
4'b0011: if (serclock) state <= 4'b0100; // Bit 1
4'b0100: if (serclock) state <= 4'b0101; // Bit 2
4'b0101: if (serclock) state <= 4'b0110; // Bit 3
4'b0110: if (serclock) state <= 4'b0111; // Bit 4
4'b0111: if (serclock) state <= 4'b1000; // Bit 5
4'b1000: if (serclock) state <= 4'b1001; // Bit 6
4'b1001: if (serclock) state <= 4'b1010; // Bit 7
4'b1010: if (serclock) state <= 4'b0000; // Stop bit
default: state <= 4'b0000; // Undefined, skip to stop
endcase
end
// Serial port data
// Ensure that the serial port has the correct data on it in each state
reg outbit;
begin
case (state)
4'b0000: outbit <= 1; // idle
4'b0001: outbit <= 0; // Start bit
4'b0010: outbit <= data[0]; // Bit 0
4'b0011: outbit <= data[1]; // Bit 1
4'b0100: outbit <= data[2]; // Bit 2
4'b0101: outbit <= data[3]; // Bit 3
4'b0110: outbit <= data[4]; // Bit 4
4'b0111: outbit <= data[5]; // Bit 5
4'b1000: outbit <= data[6]; // Bit 6
4'b1001: outbit <= data[7]; // Bit 7
4'b1010: outbit <= 0; // Stop bit
default: outbit <= 1;df // Bad state output idle
endcase
end
reg [7:0] charstate;
reg [5:0] rxstate;
begin
case (rxstate)
6'b000000: if (!rxd) rxstate <= 4'b000001;
6'b000001: if (serclockrx) rxstate <= 6'b000010;
6'b000010: if (serclockrx) rxstate <= 6'b000011;
6'b000011: if (serclockrx) rxstate <= 6'b000100;
6'b000100: if (serclockrx) rxstate <= 6'b000101;
6'b000101: if (serclockrx) rxstate <= 6'b000110;
6'b000110: if (serclockrx) begin rxstate <= 6'b000111; data[0] <= rxd; end // The sixth tact LSB reg [7:0] data;
6'b000111: if (serclockrx) rxstate <= 6'b001000;
6'b001000: if (serclockrx) rxstate <= 6'b001001;
6'b001001: if (serclockrx) rxstate <= 6'b001010;
6'b001010: if (serclockrx) begin rxstate <= 6'b001011; data[1] <= rxd; end // The 10'th tact
6'b001011: if (serclockrx) rxstate <= 6'b001100;
6'b001100: if (serclockrx) rxstate <= 6'b001101;
6'b001101: if (serclockrx) rxstate <= 6'b001110;
6'b001110: if (serclockrx) begin rxstate <= 6'b001111; data[2] <= rxd; end // The 14'th tact
6'b001111: if (serclockrx) rxstate <= 6'b010000;
6'b010000: if (serclockrx) rxstate <= 6'b010001;
6'b010001: if (serclockrx) rxstate <= 6'b010010;
6'b010010: if (serclockrx) begin rxstate <= 6'b010011; data[3] <= rxd; end // The 18'th tact
6'b010011: if (serclockrx) rxstate <= 6'b010100;
6'b010100: if (serclockrx) rxstate <= 6'b010101;
6'b010101: if (serclockrx) rxstate <= 6'b010110;
6'b010110: if (serclockrx) begin rxstate <= 6'b010111; data[4] <= rxd; end // The 22'nd tact
6'b010111: if (serclockrx) rxstate <= 6'b011000;
6'b011000: if (serclockrx) rxstate <= 6'b011001;
6'b011001: if (serclockrx) rxstate <= 6'b011010;
6'b011010: if (serclockrx) begin rxstate <= 6'b011011; data[5] <= rxd; end // The 26'th tact
6'b011011: if (serclockrx) rxstate <= 6'b011100;
6'b011100: if (serclockrx) rxstate <= 6'b011101;
6'b011101: if (serclockrx) rxstate <= 6'b011110;
6'b011110: if (serclockrx) begin rxstate <= 6'b011111; data[6] <= rxd; end // The 30'th tact
6'b011111: if (serclockrx) rxstate <= 6'b100000;
6'b100000: if (serclockrx) rxstate <= 6'b100001;
6'b100001: if (serclockrx) rxstate <= 6'b100010;
6'b100010: if (serclockrx) begin rxstate <= 6'b100011; data[7] <= rxd; end // The 34'th tact
6'b100011: if (serclockrx) rxstate <= 6'b100100;
6'b100100: if (serclockrx) rxstate <= 6'b100101;
6'b100101: if (serclockrx) rxstate <= 6'b100110;
default: rxstate <= 6'b000000;
endcase
end
endmodule
the rs232 transmitter is always sending if i type in a character into my pc
please help me to fix taht problem.
    --- Quote Start ---
    The RS232 transmitter is always sending if I type in a character into my PC
    --- Quote End ---
    This is correct, according to your code. Infact you assert 'start' periodically when clockdiv==0.
    --- Quote Start ---
    --- Quote End ---
    Thank you Cris72 I also was born in 72. For now my plan is to write a book about the Chinese module A-C8V4 that uses a Cyclone II chip.
    I am going through all examples and for now I do not have an idea what I could program here. Surely start is always called when clockdiv==0.
    --- Quote Start ---
    --- Quote End ---
    Please help me because I do not know how to start that.
    --- Quote Start ---
    --- Quote End ---
    I can't help you if you don't specify what your design is supposed to do.
    You should assert 'start' only when you really want your fpga to transmit something.
    You can use the rising edge of an input signal (for example, what's the purpose of key_in signal? you could possibly use this).
    Otherwise, if you may want your board to transmit back when it receives data: in this case you could assert start when rxstate=6'b100110
    Advice:
    That rxstate case statement is very cumbersome and somewhat unreadable. You could replace it with a simple increment of rxstate and a test on the two LSB
    for the data[n] <= rxd assignement.
    This is an example:
    (please note I wrote this code by heart; I give you no assurance it works, not even it compiles without errors)
    begin
    if (rxstate >= 6'b100110)
    begin
    if (!rxd)
    end
    else
    begin
    rxstate <= rxstate + 6'b1;
    if (rxstate[1:0] == 2'b10)
    data[rxstate[5:2]-1] <= rxd;
    end
    end
    your main problem is that start is being asserted roughly 9600 times a second and is NEVER stopping. Therefore, your device will forever continue transmitting. You have made no provision to stop the device after some condition or other has been fulfilled.
    you should only assert start when clockdiv == 0 AND [some signal which indicates you have something to transmit and want to transmit it]. Else, the cycle pasted below will keep looping forever.
    begin
    case (state)
    endcase
    end
    0also serclock and start will carry equivalent values so one of them is redundant
    here is a functioning receiver.
    greeting
    module rs232_rx (
    input clock,
    input rxd,
    output reg [7:0] led_g
    parameter idle = 2'b01;
    parameter ready = 2'b10;
    parameter busy = 2'b11;
    reg [1:0] state=idle;
    reg [3:0] rxd_sr=4'b1111;
    reg [7:0] rxsr=8'b00000000;
    reg [3:0] rxbitcnt;
    reg [11:0] rxcnt;
    reg [7:0] rx_data;
    reg rx_en = 0;
    parameter rcv_bit_per = 2604; //19200 Baud
    always @(posedge clock ) begin
    if(rx_en==1)
    led_g =rx_data;
    end
    rxd_sr = {rxd_sr[2:0], rxd};
    rx_en = 0;
    case (state)
    idle:
    begin
    if(rxd_sr[3:2] == 2'b10)
    begin
    rxcnt =1302;
    rxbitcnt =0;
    state =busy;
    end
    end
    busy:
    begin
    if(rxbitcnt<9)
    begin
    if(rxcnt < rcv_bit_per)
    rxcnt =rxcnt+1;
    else
    begin
    rxcnt =0;
    rxbitcnt <=rxbitcnt+1;
    rxsr ={rxd_sr[2], rxsr[7:1]};
    end
    end
    else
    state=ready;
    end
    ready:
    begin
    rx_data =rxsr;
    state =idle;
    rx_en =1;
    end
    endcase
    end
    endmodule
