11 years ago
i have question about verilog. i coudln't make one clock. will u help me please.
i attached file & picure.
our team creating uart verilog code. by using modelsim.
i have 4 modules for FPGA and one module for simulation as like testbench.
so i will explain shortly. in code, when transmit is 1, enable= 1 ( it create one clock)
transmit ________l------------l____________________
enable __________--___________________________
but, i coudln't fix that problem... when i run code, output wire enable is not connected.
the code is in '"module dld"
Thank you.
    You did not initialize the reset value for reg a and reg b in module "dld". Like reg a=0,b =0; Or change the always process like below
    always @ (posedge clk or posedge reset)
    if begin
    a <= 0;
    b <= 0;
    end else
    begin
    if(counter == 12'd2604)
    begin
    a <= transmit;
    b <= ~a;
    end
    end
    Thank you for your help. I appreciate. Haha thanks! I was not good yesterday about feeling but right now I feel happy ! Thanks again. Sleep well !! Good night
    --- Quote Start ---
    if begin
    a <= 0;
    b <= 0;
    end else
    begin
    begin
    a <= transmit;
    b <= ~a;
    end
    end
    --- Quote End ---
