15 years ago
I got error because of not proper use of std_logic and bit, please help me in solving
-- Company:
-- Engineer:
-- Create Date: 15:16:54 02/14/2011
-- Design Name:
-- Module Name: glu - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
--ENTITY Declarations
ENTITY glu is
port(
Data_reg: OUT STD_LOGIC_vector(11 downto 0);
Creg: out STD_LOGIC_vector(4 downto 0));
end glu;
--Architecture Body
architecture Behavioral of glu is
TYPE Memory IS ARRAY (0 TO 1026) OF STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL Ram : Memory;
rows and 8 bit in each rowSIGNAL Temp1,Temp2,Temp3: STD_LOGIC_VECTOR(15 DOWNTO 0) ;
SIGNAL A1A0,CS: STD_LOGIC_VECTOR(1 DOWNTO 0) ;
SIGNAL Temp2,Mirror_Num10 ,Mirror_Num20,Axis10,Temp10,Temp40,Temp3:STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL Temp1,Mirror_Num ,Mirror_Num2 ,Temp4,Axis : BIT_VECTOR(15 DOWNTO 0);
SIGNAL Cur_Add: STD_LOGIC_VECTOR(31 downto 0);
SIGNAL Base_Add:STD_LOGIC_VECTOR:=x"00000000";
SIGNAL Mnum_Add:STD_LOGIC_VECTOR:=x"00000403";
SIGNAL flag:STD_LOGIC_VECTOR:= x"00000400";
SIGNAL Axis_Add:STD_LOGIC_VECTOR:=x"00000401";
SIGNAL X:STD_LOGIC_VECTOR:="000000000000000";
SIGNAL Y :STD_LOGIC_VECTOR:="0000000000000010";
BEGIN
process(Ram(Conv_Integer(flag))) -- Process begin and we take the flag in sensitivity list.
BEGIN
IF ( Ram(Conv_Integer(flag))='1') THEN
Mirror_Num(15 DOWNTO 8) <= CONV_STD_LOGIC_VECTOR (Ram(Conv_Integer(Mnum_Add)));
--Store the value of the mirror number in the Temp1
Mirror_Num(7 DOWNTO 0) <= CONV_STD_LOGIC_VECTOR (Ram(Conv_Integer(Mnum_Add+1)));
Axis(15 DOWNTO 8) <= CONV_STD_LOGIC_VECTOR (Ram(Conv_Integer(Axis_Add)));
--Store the value for choosing X or Y axis in temp2
Axis(7 DOWNTO 0) <= CONV_STD_LOGIC_VECTOR (Ram(Conv_Integer(Axis_Add+1)));
Mirror_Num2 <= Mirror_Num sla 1 ; --Multiply mirror number by 2
If(Axis=X) THEN --Check for the X axis
Cur_Add<= (Base_Add + (Mirror_Num sla 2) + Axis); --If we have to move the mirror in X axis then current address of BRAM is
Temp1 <= Mirror_Num2 + Axis ;
ELSIf(Axis=Y) THEN --Check for the Y axis
Temp1 <= Axis sra 1 + Mirror_Num2;
END IF;
Temp4 <= Temp1 sra 2;
Mirror_Num10 <= CONV_STD_LOGIC_VECTOR( Mirror_Num) ;
Mirror_Num20 <= CONV_STD_LOGIC_VECTOR ( Mirror_Num2 ) ;
Axis10 <= CONV_STD_LOGIC_VECTOR ( Axis ) ;
Temp10 <= CONV_STD_LOGIC_VECTOR ( Temp1 ) ;
Temp40 <= CONV_STD_LOGIC_VECTOR ( Temp4 ) ;
DATA_reg(11:8)<=Ram(Conv_Integer(Cur_Add))(3:0); -- Put the value of the current address of BRAM to Data reg
DATA_reg(7:0)<=Ram(Conv_Integer(Cur_Add+1));
Temp2 <= conv_STD_LOGIC_vector((conv_integer(Temp1) mod 4),16); --Calculation for the Position in Particular DAC according to mirrir number and axis selection.
A1A0 <= Temp2(1 DOWNTO 0);
Temp3 <= conv_STD_LOGIC_vector(conv_integer(Temp4),16) ;
IF(Temp3="0000000000000000") THEN
CS<="01";
ELSIF(Temp3="0000000000000001") THEN
CS<="10";
END IF;
--Calculation for chip select
CS <= Temp3(1 DOWNTO 0);
Creg(4 DOWNTO 3) <= CS ; -- Put the value for chip select and A1A0 in the control registor.
Creg(2 DOWNTO 1) <= A1A0 ;
Creg(0) <= '0' ; -- set the value of lsb of control registor to 0 for R/(W)bar
-- If flag=0 then exit.
END IF;
END PROCESS;
Creg(4 DOWNTO 3) <= "11" ;
flag <= 0;
END Behavioral;
    a std_logic_vector is not a bit vector.
    Why not just declare Temp1,Mirror_Num ,Mirror_Num2 ,Temp4,Axis as std_logic_vectors?
    You might want to try using the numeric_std package. That has signed and unsigned types that support sla and sra, and you can convert them to std_logic_vector.
    Actually can u tell me the instruction for converting std_logic_vector to bit_vector.
    And from integer to bit_vector and vice versa.
    You can just use the to_stdlogicvector/to_stdlogic/to_bitvector/to_bit functions in the std_logic_1164 library.
    The numeric_std library has sra and sla functions for unsigned and signed types, that you can convert to and from integer.
    signal s : signed(7 downto 0);
    s <= s sra 5;
    i <= to_integer(s);
    I use this ,
    mul<= mul sra 5;
    temp<= to_integer(mul);
    but this gives me error defination of operator match here
    have you included the numeric_std library and deleted the std_logic_arith library?
    I use these library
    library IEEE;
    use IEEE.numeric_std.all;
    The std_logic_arith library defines its own signed and unsigned types, but does not include sra and srl functions. It is also NOT an IEEE standard library (neither is std_logic_signed/unsigned)
    numeric_std defines its own signed/unsigned types and also includes sra/srl functions, and it IS the IEEE standard library. Using numeric_std and std_logic_arith in the same file causes conflicts that will cause neither of them to work (unless you reference everything specifically).
    The answer is to delete std_logic_arith.
