I can't change the license
こんにちは!
新しいコンピュータを入手し、Self-Service Licensing Centerでライセンスを変更しようとしましたが、「1つ以上のライセンスに利用可能なRehostがないため、ホスト情報を更新できません」というメッセージが表示され、NIC IDを変更できませんでした。
使用可能なリホストの数は 3 です。
助けてください。
Is the license file that you want to rehost a purchased license or evaluation license?
If it is evaluation license, then you just need to generate a new evaluation license from the SSLC.
If it is a purchased license, check the Available Rehosts number # for the license rehost.
If the rehost number is 0, then you can not rehost the license.
If that the case, could you provide the screenshot of the license file you plan to rehost (LR-XXXXXXX) and the Available Rehosts number #?
I will send you a private email for further details.
Please checkout this user guide on how to rehost the license if the Available Rehosts number # is Not Zero.
Richard Tan
- RichardT_altera
Richard Tan
- ken-salt
Sorry
I made a mistake and marked it as Accepted Solution.
I have 3 rehosts available.
- RichardT_altera
After further debug, the root cause is due to changing the NIC ID in the Computer Profile in the All Computers. This will rehost all the license file tied to that NIC ID. Since the rehost cant be made (stated in the warning message), that mean at least one license tied to that NIC ID does not have available rehost #.
User will need to check All Licenses, to check if there is any license file with a 0 rehost number #, being tied to that specific NIC ID.
If user plan to rehost one license only, it is recommend to rehost that particular license file directly, instead of changing the computer profile (which rehost all license bundle under the same NIC ID).
Additionally, you may Create a New Computer (with a new name) for your new NIC ID.
Richard Tan
- RichardT_altera
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
