bswag
7 years agoI am using quartus pro 18.1 I get a error unconstrained ports can only be associated in whole if I cast a unconstrained std_logic_vector to an unsigned for my generic memory
I have memory block I have memory as follows: entity memory is port ( clk : in std_logic; din : std_logic_vector; wr : in std_logic; dout: std_logic_vector ); When I instantiate for exa...
IDeyn
Contributor
7 years agoHi bswag.
There is a perfect reference about VHDL type casting - http://www.synthworks.com/papers/vhdl_math_tricks_mapld_2003.pdf
Hope it helps.
Ivan
