How to write testbench for 18x18 multiplier
I need to write testbench for 18x18 multiplier, which reads input from a text file (at least 10 numbers). Every input has to have at least 1 one and 1 zero in 4 most significant bits, and half of the tested numbers are negative. If the results are correct, must be tested in testbench file.
Code is simple:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY signed_mult18 is
PORT( a : IN SIGNED (17 DOWNTO 0);
b : IN SIGNED (17 DOWNTO 0);
result : OUT SIGNED (35 DOWNTO 0));
END ENTITY;
ARCHITECTURE rtl OF signed_mult18 IS
BEGIN
result <= a * b;
END rtl;Thank you very much.
- Vicky1
hi,
Here in community, no one will provide complete code so user should come with their own code/logic & people in community may help to make it correct/better appropriate.
In this case, I would like to suggest you need to use the STD.textio package that defines routines for reading and writing to
a text file , refer the below old thread ,
https://forums.intel.com/s/question/0D50P00003yyR8zSAE/vhdl-textio-hread-problem
Best Regards
Vikas Jathar
- Abe
You can create a basic testbench usign the Quartus university VWF editor and then have it generate VHDL/Verilog bench. Then modify the bench accordingly to read / write from files using textio library.
