How to write data in a file from FPGA
I am a beginner using Quartus and programming FPGA. I need to implement a binary search on FPGA and record the result of the search in a file (a 7 binary code each time). Below is the implementation I did using Quartus and it is synthesizable.
I just need help on how to store the D_out, every time the data is ready (valid bit is high).
- _AK6DN_
Store it in a file where? On what device/media? On your Windows PC filesystem? Or on an SDcard attached to your FPGA?
Probably the simplest solution is to dump the data out using a UART serial module and connect the serial pins thru the
appropriate level conversion logic to a USB serial converter plugged into your PC. Then you can capture the result on a terminal window. - MG007
Thank you for the reply.
Storing data in anyway is useful for me. Any way that is easier works for me.
Can you please explain a bit more about the solution you mentioned? What hardware and software I will need to do that?
- _AK6DN_
Until we know what your hardware platform it is hard to be specific.
What FPGA are you using? Is it on a standard development board, or on a custom board of your own design?
What version of Quartus on which platform (Windows, Linux, etc)?
- MG007
FPGA is developement board DE2-115. An I am using Quartus prime 21.1 on Windows.
- _AK6DN_
DE2-115 is a very nice development board, I also happen to have one of those.
It has a standard 9p RS232 compatible serial port, so you could just connect that to a PC via a COM port or a SERIAL/USB adapter.
So you could just implement a UART module in the FPGA and write text/data to the serial port and capture it on a PC.
It also has an SDcard socket, but that will require much more effort to use in any effective way.
Same for the etherNet port connections on the board.
- MG007
Thanks for the reply.
So I only need to implement UART module in FPGA through Quartus and assign the pin of the module to Rs-232 and connect the R-232 to the PC?
- _AK6DN_
Correct.
In fact you probably only need a UART transmitter module to send data from the FPGA to the PC.
A UART transmitter is the conceptually simpler to implement compared to a UART receiver.
- RichardT_altera
Thank you for the quick and helpful suggestions from the community!
Hi @MG007,
Do you need further help in regards to this case?
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
- RichardT_altera
We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transitioning your inquiry to our community support.
We apologize for any inconvenience this may cause and we appreciate your understanding.
If you have any further questions or concerns, please don't hesitate to let us know.
Richard Tan
- michaelaskew
module BinarySearch (
input logic clk,
input logic [6:0] target,
input logic valid,
output logic [6:0] D_out
);reg [6:0] result;
integer file_out;initial file_out = $fopen("output.txt", "w");
always_ff @(posedge clk) begin
if (valid) begin
result <= D_out;
$fwrite(file_out, "%b\n", result);
end
endendmodule
This shortened version retains the essential components for storing D_out when valid is high and writes the result to a file during simulation. Adjust the file path and name as needed.
Menupro - _AK6DN_
The above code snippet will ONLY work within a logic simulation environment.
System tasks like $fopen() $fwrite() $fread() $fclose() etc are not supported in synthesis and on real hardware.
Which was the question the original poster had: saving data from an FPGA design on a physical development board.
- billmax
If it were me I would use SignalTap with appropriately selected conditional storage qualifiers, then export the data / create signaltap list file.
