MG007
2 years agoHow to write data in a file from FPGA
Hello, I am a beginner using Quartus and programming FPGA. I need to implement a binary search on FPGA and record the result of the search in a file (a 7 binary code each time). Below is the implem...
michaelaskew
2 years agomodule BinarySearch (
input logic clk,
input logic [6:0] target,
input logic valid,
output logic [6:0] D_out
reg [6:0] result;
integer file_out;
initial file_out = $fopen("output.txt", "w");
always_ff @(posedge clk) begin
if (valid) begin
result <= D_out;
$fwrite(file_out, "%b\n", result);
end
end
endmodule
This shortened version retains the essential components for storing D_out when valid is high and writes the result to a file during simulation. Adjust the file path and name as needed.
Menupro
