Amir21's avatar
Amir21
6 years ago
How to use "set_clock_groups" properly to constrain 2 asynchronous clocks in different clock domains
In my project, I have two different clock domains:
1. The first domain use the "sys_clk" from 10[MHz] external oscillator.
2. The second domain use the "pll_clk" (60[MHz]) that generated by PLL module from source of 100[MHz] external oscillator.
It says that the setup time slack of pll_clk is negative, I see the worst-case timing paths, I found that the launch clock is sys_clk ,and the latch clock is pll_clk.
Those two clocks are completely unrelated (have different ideal clock sources), when I'm trying to use the "set_clock_groups" definition In my SDC file, as follow:
set_clock_groups -asynchronous -group {sys_clk} -group {uart_pll|altpll_component|auto_generated|pll|clk[1]}
I get those two warning messages:
Warning (332174): Ignored filter at project.sdc(67): "uart_pll|altpll_component|auto_generated|pll|clk[1]" could not be matched with a clock
Warning (332049): Ignored set_clock_groups at project.sdc(67): Argument -group with value uart_pll|altpll_component|auto_generated|pll|clk[1] could not match any element of the following types: ( clk )
I don't know how to resolve it,
I will be glad to learn from your experience.
  • Here's what I did. Works as expected.
    create_clock -period 20.0 -name CLOCK_50 [get_ports {CLOCK_50}]
    create_generated_clock -source {pll|altpll_component|pll|inclk[0]} -divide_by 5 -multiply_by 8 -duty_cycle 50 -name CPUCLK {pll|altpll_component|pll|clk[0]}
    create_generated_clock -source {pll|altpll_component|pll|clk[0]} -divide_by 5000 -duty_cycle 50 -name RTCCLK {dk8ea_clock:rtc|rtcclk}
    set_clock_groups -asynchronous -group {CLOCK_50} -group {CPUCLK} -group {RTCCLK} -group {altera_reserved_tck}
    Note you use the NAME of the clock groups in the set_clock_groups command, not the signal or pin names.
  • ak6dn's avatar
    ak6dn
    • Amir21's avatar
      Amir21
      I tried it and it worked perfectly!
      Thanks a lot, really appreciate it.
      Aizik Amos.
  • ak6dn's avatar
    ak6dn
    (duplicate but I can't delete it)
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    Hi Aizik Amos,
    KhaiY
