Amir21
6 years agoHow to use "set_clock_groups" properly to constrain 2 asynchronous clocks in different clock domains
In my project, I have two different clock domains:
1. The first domain use the "sys_clk" from 10[MHz] external oscillator.
2. The second domain use the "pll_clk" (60[MHz]) that generated...
- 6 years ago
Here's what I did. Works as expected.
create_clock -period 20.0 -name CLOCK_50 [get_ports {CLOCK_50}]
create_generated_clock -source {pll|altpll_component|pll|inclk[0]} -divide_by 5 -multiply_by 8 -duty_cycle 50 -name CPUCLK {pll|altpll_component|pll|clk[0]}
create_generated_clock -source {pll|altpll_component|pll|clk[0]} -divide_by 5000 -duty_cycle 50 -name RTCCLK {dk8ea_clock:rtc|rtcclk}
set_clock_groups -asynchronous -group {CLOCK_50} -group {CPUCLK} -group {RTCCLK} -group {altera_reserved_tck}
Note you use the NAME of the clock groups in the set_clock_groups command, not the signal or pin names.
KhaiChein_Y_Intel
6 years agoHi,
Have you tried ak6dn's suggestion?
KhaiY
