Dear rbugalho,
I had tried both your suggestions before with no success :(
Timing report for "set_max_delay -from [get_ports read_n] -to [get_ports ack]" returns: "No paths were found"
For the second approach, I used:
create_clock -name dsp_clk -period 9.804
set_input_delay -clock { dsp_clk } -min 0
set_input_delay -clock { dsp_clk } -max 0
set_output_delay -clock { dsp_clk } -min 0
set_output_delay -clock { dsp_clk } -max 0
Timing report for "set_input_delay" returns: "No paths were found" (Which makes sense, as read_n is connected to the registers clock pin, not data pin as usual.)
Timing report for "set_output_delay" returns the clock pin to output port timing, which is not what I need. I'm looking for the clear to output timing.
My best approach so far is when using the following report:
report_timing -from_clock { dsp_clk } -recovery -npaths 10 -detail full_path -panel_name {read_n to ack_internal|q}
This shows the path from read_n port to ack_internal|q pin. But using "recovery" implements that I want to synchronize with the fpga_clk which is not what I'm after.
Is there some way of splitting timings into two "set_max_delay", one from read_n port to ack_internal|q and another for ack_internal|q to ack port? I tried some stuff like:
set_max_delay -from -to 7
set_max_delay -from -to 5
But all of them return: "No paths were found"!
Am I doing something wrong, or is this truly impossible to constrain?
Simon
