9 years agoHow to perform logical operation for two signal generated at diiferent clock cycle?
Hi everyone,
i have to random binary data signal,one starts at 100ns and ends at 1450ns ,another data signal starts from 14350ns and ends at 15000ns. I want perform xor operation of these two data signal in verilog.How to shift the signal or how to make the second data signal to start from 100ns so that both signal have data at the same at same clock cycle?.please help me....i'm new to this verilog code. thank you.6 Replies
--- Quote Start --- Hi everyone, i have to random binary data signal,one starts at 100ns and ends at 1450ns ,another data signal starts from 14350ns and ends at 15000ns. I want perform xor operation of these two data signal in verilog.How to shift the signal or how to make the second data signal to start from 100ns so that both signal have data at the same at same clock cycle?.please help me....i'm new to this verilog code. thank you. --- Quote End --- one way is to use two fifos, one dual clk on clk1/clk2, the other single on clk1. once both have data read out and xor. Or use handshake approach instead of fifo but a shallow fifo is almost same cost as handshake. - Altera_Forum
can you please provide me the verilog code.. It will be very useful for me. i'm using microsemi Libero Soc 11.4v software to write verilog code.
Thanks for the reply :)....
can you please provide me the verilog code.. It will be very useful for me. i'm using microsemi Libero Soc 11.4v software to write verilog code. - Altera_Forum
I have a verilog code for memeory.I got the output for presynthesis,but postsynthesis i'm unable to get the simulation rersult
This is my actual code for memory............... ............................................................ `timescale 1ns/100ps module main( sysclk, reset,read_out); //<statements> input sysclk; input reset; output read_out; reg [7:0] count1_1,count2_1; reg [7:0] count12_1,count11_1; wire [7:0]count11,count12,count1,count2; reg count1_en,count2_en,count11_en ,count12_en; ////////////////////////////////////// //////////////DATA FOR MEMORY1 /////////////////////////////// // counter1 always @( posedge sysclk) begin if (reset==0) begin count11_en <= 1; count11_1<= {8{1'b0}} ; end else if(count11_en == 1) if(count11!= 8'd222) count11_1<= count11_1 + 1; if(count11_1== 8'd222) begin count11_en <= 0; count11_1<=8'd0; end end assign count11=count11_1; always @( posedge sysclk) begin if(count11==0) begin count12_en <= 1; count12_1 <= {8{1'b0}} ; end else if(count12_en == 1) if(count12_1!= 8'd222) count12_1 <= count12_1 + 1; if(count12_1==222) begin count12_en <= 0; count12_1<=8'd0; end end assign count12=count12_1; wire[7:0] read_out1; ////////////////////////////////////////////////////////////////////// // Instantiate Unit Under Test: memory1 ////////////////////////////////////////////////////////////////////// memory1 memory1_0( .WD(count11), .RD(read_out1), .WEN(count11_en), .REN( count12_en), .WADDR(count11), .RADDR(count12), .WCLK(sysclk), .RCLK(sysclk), .RESET(reset) ); .................................................................. ................................................................. Warning: (vsim-3017) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Too few port connections. Expected 9, found 7. # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'read_out1' not found in the connected module (1st connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'count11_1' not found in the connected module (2nd connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'count12_1' not found in the connected module (3rd connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'count11_en' not found in the connected module (4th connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'count12_en' not found in the connected module (5th connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'sysclk_c' not found in the connected module (6th connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'reset_c_0' not found in the connected module (7th connection). # # Region: /tb_mem/main_0/memory1_0 # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'WD'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'RD'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'WEN'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'REN'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'WADDR'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'RADDR'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'WCLK'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'RCLK'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'RESET'. # # Error loading design # Error: Error loading design # Pausing macro execution # MACRO ./run.do PAUSED at line 16 .............................................................................. ................................................................................ the above mentioned error i got during postsynthesis simulation i'm not getting how to solve this error please help in this........... i'm using libero Soc11.4v software to write and code and modelsim microsemi 10.3c simulator . please help to solve this problem - Altera_Forum
The binary data signal is 1 bit or multiple bits??
This code will give you an idea to implement.
// Design code module Slave (clk,a,b,counter); input clk; input a; input b; input [31:0] counter; reg [8:0] Y; reg [8:0] storea=0; reg [8:0] mem1; reg [8:0] storeb=0; reg [8:0] mem2; always @(posedge clk) begin storea <= {storea[7:0],a}; end always @(posedge clk) begin storeb <= {storeb[7:0],b}; end always @(posedge clk) begin if(counter == 'd11) mem1 <= storea; else if(counter == 'd21) mem2 <= storeb; end always @(counter) begin if(mem1!== 'dx && mem2 !== 'dx) Y = mem1 & mem2; else Y = 'd0; end endmodule //Testbench code module TB; reg clk=0; reg a=0; reg b=0; int counter = 0; Slave D1 (.clk(clk),.a(a),.b(b),.counter(counter)); always# 1 clk = ~clk; always @(posedge clk) begin counter<= counter+1; end always @(counter) begin if(counter >= 2 && counter <= 10) a = $random; else if(counter >= 15 && counter <= 20) b = $random; else begin a = 0;b = 0; end end /*always # 100 a = $random; # 1450 a = 0; end initial begin # 14350 b = $random; # 15000 b = 0; end */ initial # 100 $finish; initial begin $dumpfile("design.vcd"); $dumpvars; end endmodule Thanks
