9 years agoHow to perform logical operation for two signal generated at diiferent clock cycle?
Hi everyone, i have to random binary data signal,one starts at 100ns and ends at 1450ns ,another data signal starts from 14350ns and ends at 15000ns. I want perform xor operation of these two d...
9 years agoI have a verilog code for memeory.I got the output for presynthesis,but postsynthesis i'm unable to get the simulation rersult
This is my actual code for memory............... ............................................................ `timescale 1ns/100ps module main( sysclk, reset,read_out); //<statements> input sysclk; input reset; output read_out; reg [7:0] count1_1,count2_1; reg [7:0] count12_1,count11_1; wire [7:0]count11,count12,count1,count2; reg count1_en,count2_en,count11_en ,count12_en; ////////////////////////////////////// //////////////DATA FOR MEMORY1 /////////////////////////////// // counter1 always @( posedge sysclk) begin if (reset==0) begin count11_en <= 1; count11_1<= {8{1'b0}} ; end else if(count11_en == 1) if(count11!= 8'd222) count11_1<= count11_1 + 1; if(count11_1== 8'd222) begin count11_en <= 0; count11_1<=8'd0; end end assign count11=count11_1; always @( posedge sysclk) begin if(count11==0) begin count12_en <= 1; count12_1 <= {8{1'b0}} ; end else if(count12_en == 1) if(count12_1!= 8'd222) count12_1 <= count12_1 + 1; if(count12_1==222) begin count12_en <= 0; count12_1<=8'd0; end end assign count12=count12_1; wire[7:0] read_out1; ////////////////////////////////////////////////////////////////////// // Instantiate Unit Under Test: memory1 ////////////////////////////////////////////////////////////////////// memory1 memory1_0( .WD(count11), .RD(read_out1), .WEN(count11_en), .REN( count12_en), .WADDR(count11), .RADDR(count12), .WCLK(sysclk), .RCLK(sysclk), .RESET(reset) ); .................................................................. ................................................................. Warning: (vsim-3017) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Too few port connections. Expected 9, found 7. # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'read_out1' not found in the connected module (1st connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'count11_1' not found in the connected module (2nd connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'count12_1' not found in the connected module (3rd connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'count11_en' not found in the connected module (4th connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'count12_en' not found in the connected module (5th connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'sysclk_c' not found in the connected module (6th connection). # # Region: /tb_mem/main_0/memory1_0 # ** Error: (vsim-3063) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): Port 'reset_c_0' not found in the connected module (7th connection). # # Region: /tb_mem/main_0/memory1_0 # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'WD'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'RD'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'WEN'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'REN'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'WADDR'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'RADDR'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'WCLK'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'RCLK'. # # ** Warning: (vsim-3722) C:/Users/Krishna/Desktop/monika/HARDWARETEST/RSTEST/synthesis/main.v(9290): [TFMPC] - Missing connection for port 'RESET'. # # Error loading design # Error: Error loading design # Pausing macro execution # MACRO ./run.do PAUSED at line 16 .............................................................................. ................................................................................ the above mentioned error i got during postsynthesis simulation i'm not getting how to solve this error please help in this........... i'm using libero Soc11.4v software to write and code and modelsim microsemi 10.3c simulator . please help to solve this problem
