12 years ago
How to make a averager in VHDL
I have just readed a piece of VHDL code. It is used to average the signal value from AD(14 bit).
The code i write below here:
process(CLK80) begin
if(CLK80'event and CLK80='1') then
if(samplingTriggerReg='1') then -- synchronization with the sampling trigger
avCStateReg <= "00000";
else
case avCStateReg is
when "00000"=> if(sigCLatchReg='1') then avCStateReg<="00001"; end if;
when "00001"=> if(sigCLatchReg='1') then avCStateReg<="00011"; end if;
when "00011"=> if(sigCLatchReg='1') then avCStateReg<="00111"; end if;
when "00111"=> if(sigCLatchReg='1') then avCStateReg<="01111"; end if;
when "01111"=> if(sigCLatchReg='1') then avCStateReg<="11111"; end if;
when "11111"=> if(sigCLatchReg='1') then avCStateReg<="11110"; end if;
when "11110"=> if(sigCLatchReg='1') then avCStateReg<="11100"; end if;
when "11100"=> if(sigCLatchReg='1') then avCStateReg<="11000"; end if;
when "11000"=> if(sigCLatchReg='1') then avCStateReg<="10000"; end if;
when "10000"=> if(sigCLatchReg='1') then avCStateReg<="00000"; end if;
when others => avCStateReg<="00000";
end case;
end if;
end if;
end process;
dfTrigCReg <= '1' when avCStateReg="10000" else '0';
avSStateReg <= "00000";
else
case avSStateReg is --gray counter?
when "00000"=> if(sigSLatchReg='1') then avSStateReg<="00001"; end if;
when "00001"=> if(sigSLatchReg='1') then avSStateReg<="00011"; end if;
when "00011"=> if(sigSLatchReg='1') then avSStateReg<="00111"; end if;
when "00111"=> if(sigSLatchReg='1') then avSStateReg<="01111"; end if;
when "01111"=> if(sigSLatchReg='1') then avSStateReg<="11111"; end if;
when "11111"=> if(sigSLatchReg='1') then avSStateReg<="11110"; end if;
when "11110"=> if(sigSLatchReg='1') then avSStateReg<="11100"; end if;
when "11100"=> if(sigSLatchReg='1') then avSStateReg<="11000"; end if;
when "11000"=> if(sigSLatchReg='1') then avSStateReg<="10000"; end if;
when "10000"=> if(sigSLatchReg='1') then avSStateReg<="00000"; end if;
when others => avSStateReg<="00000";
end case;
end if;
end if;
end process;
dfTrigSReg <= '1' when avSStateReg="10000" else '0';
process(CLK80)
begin
if (CLK80'event and CLK80='1') then
if (sigCLatchReg='1') then
avSigCReg(0)
<= sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg;
for I in 1 to 9 loop
avSigCReg(I) <= avSigCReg(I-1)
+ (sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg);
end loop;
end if;
end if;
end process;
process(CLK80)
begin
if (sigSLatchReg='1') then
avSigSReg(0)
<= sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg;
avSigSReg(I) <= avSigSReg(I-1)
+ (sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg);
end loop;
end if;
end if;
end process;
i dont konw why the designer do this&#65306; avSigCReg(0) <= sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg;
avSigCReg is is array (0 to 9) of signed(17 downto 0)&#65292;
I think this code is calculate the average value of 10 signal .
But I dont understand it ? Thanks for giving your idea.
    hi kaz&#65281;
    Maybe I can ask you another VHDL code after this one. The data which is summed will be taken into a digital filter. The code is shown below:------------------- FIR FILTER ------------------
    process(CLK80)
    begin
    if (DFTrigCReg='1') then
    for I in 0 to firLength-1 loop
    CQRealReg(I) <= avSigCReg(9)(17 downto 4) * DFcoeff(I);
    end loop;
    CSRealReg(0) <= CQRealReg(0)(23) & CQRealReg(0)(21 downto 0);
    for I in 1 to firLength-1 loop
    CSRealReg(I) <= CSRealReg(I-1) + (CQRealReg(I)(23) & CQRealReg(I)(21 downto 0));
    end loop;
    end if; --
    end if; -- CLK
    end process;
    I think the DFcoeff is filter coefficient. But why the designer do the process like this" CSRealReg(0) <= CQRealReg(0)(23) & CQRealReg(0)(21 downto 0);"
    That will be sign extension, ensuring that the slices arrays stay +ve or -ve correctly.
    It reads better if you use the resize() function.
    Looking at that code, it wont build the adder tree as I expect it, it just creates FirLength-1 output values (you usually end up with a single output).
    --- Quote Start ---
    --- Quote End ---
    Yes, but I dont know the resize() function. And maybe the CSRealReg(FirLength-1) is the output which I want . If you're interesting the complete vhdl code you can see it in the attchment, Tricky. Thanks for your help.
