12 years ago --- Quote Start --- That will be sign extension, ensuring that the slices arrays stay +ve or -ve correctly. It reads better if you use the resize() function. Looking at that code, it wont build the adder tree as I expect it, it just creates FirLength-1 output values (you usually end up with a single output). --- Quote End --- Yes, but I dont know the resize() function. And maybe the CSRealReg(FirLength-1) is the output which I want . If you're interesting the complete vhdl code you can see it in the attchment, Tricky. Thanks for your help.
