16 years ago
How to instantiate a dual RAM with different widths on the R/W port
the dual RAM:
Write port:128×16-bits
reading port: 2048×1-bit
I pefer HDL design input such VHDL or Verilog, please DO NOT tell me to instantiate this dual RAM by megawizard:)
Thanks a lot!
    Quartus II 8.0 fail to infer following code to RAM:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.STD_LOGIC_ARITH.ALL;
    use IEEE.STD_LOGIC_UNSIGNED.ALL;
    entity test_build is
    port (
    clka : in std_logic;
    clkb : in std_logic;
    addr_a : in std_logic_vector(6 downto 0);--in natural range 0 to 127;
    data_a : in std_logic_vector(63 downto 0);
    addr_b : in std_logic_vector(8 downto 0 );--in natural range 0 to 511;
    q_b : out std_logic_vector(15 downto 0)
    end entity;
    architecture rtl of test_build is
    -- Build a 2-D array type for the RAM
    type word_t is array (2**9-1 downto 0) of std_logic_vector (15 downto 0);
    shared variable mem : word_t;
    signal addr_b_r : std_logic_vector(8 downto 0);--integer;
    begin
    process(clka)
    begin
    if rising_edge(clka) then
    --mem(conv_integer(addr_a)) := data_a;
    mem(conv_integer(addr_a) * 4+0) := data_a(15 downto 0);
    mem(conv_integer(addr_a) * 4+1) := data_a(31 downto 16);
    mem(conv_integer(addr_a) * 4+2) := data_a(47 downto 32);
    mem(conv_integer(addr_a) * 4+3) := data_a(63 downto 48);
    end if;
    end process;
    --rd_addr_t <= std_logic_vector(to_unsigned(addr_b, 9) );
    process(clkb)
    begin
    if rising_edge(clkb) then
    addr_b_r <= addr_b;
    q_b <= mem(conv_integer(addr_b_r));
    -- case (addr_b_r(1 downto 0)) is
    -- when "11" =>
    -- q_b <= q_t(63 downto 48);
    -- when "10" =>
    -- q_b <= q_t(47 downto 32);
    -- when "01" =>
    -- q_b <= q_t(31 downto 16);
    -- when "00" =>
    -- q_b <= q_t(15 downto 0);
    -- when others =>
    -- q_b <= x"0000";
    -- end case;
    end if;
    end process;
    --q_b <= mem(addr_b_r);
    --alt_ram : altsyncram
    --generic map (
    -- Width_a => 64,
    -- width_b => 16,
    -- widthad_a => 7,
    -- widthad_b => 9
    --port map (
    -- clock0 => clka,
    -- clock1 => clkb,
    -- data_a => data_a,
    -- address_a => std_logic_vector(to_unsigned(addr_a, 7) ),
    -- address_b => std_logic_vector(to_unsigned(addr_b, 9) ),
    -- q_b => q_b
    end architecture rtl;
    As Tricky posted, it's not a bad idea to add muxes on the output, like the quoted part using "case" above. U need to asure the width of R/W ports is same, as well as the address.
    I don't see a purpose of using a shared variable for RAM inference, also I doubt if it's supported in this place by Quartus? It's never mentioned in the Quartus Handbook.
    In the above code, you are trying to write to four consecutive RAM addresses simultanously. This can't work in a single clock cycle.
    end if;
    If you want to emulate different port width's with equal port width RAM, you must do it the other way around: Define the RAM width the larger width and use individual byteenable signals, when writing to the smaller port is intended
    Shared variables should not be synthesizable, but it appears they are in Quartus!.
    Quartus II 8.0 DO infer following code to dual port RAM:
    library IEEE;
    --use ieee.numeric_std.all;
    generic
    DATA_WIDTH : natural := 64;
    ADDR_WIDTH : natural := 7
    port (
    wren : in std_logic := '1';
    addr_a : in std_logic_vector(ADDR_WIDTH-1 downto 0);--in natural range 0 to 127;
    data_a : in std_logic_vector(DATA_WIDTH-1 downto 0);
    rden : in std_logic := '1';
    addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0 );--in natural range 0 to 511;
    end entity;
    --type mem_t is array(0 to 511) of std_logic_vector(15 downto 0);
    type word_t is array (2**ADDR_WIDTH-1 downto 0) of std_logic_vector (DATA_WIDTH-1 downto 0);
    --attribute ramstyle : string;
    --attribute ramstyle of mem : variable is "no_rw_check";
    signal addr_b_r : std_logic_vector(ADDR_WIDTH-1 downto 0);--integer;
    signal q_t : std_logic_vector(DATA_WIDTH-1 downto 0);
    begin
    process(clka)
    begin
    if(wren = '1') then
    -- mem(conv_integer(addr_a) * 4+0) := data_a(15 downto 0);
    -- mem(conv_integer(addr_a) * 4+1) := data_a(31 downto 16);
    -- mem(conv_integer(addr_a) * 4+2) := data_a(47 downto 32);
    -- mem(conv_integer(addr_a) * 4+3) := data_a(63 downto 48);
    end if;
    end if;
    end process;
    process(clkb)
    begin
    if(rden = '1') then
    addr_b_r <= addr_b;
    q_t <= mem(conv_integer(addr_b_r));
    --q_b <= q_t(to_unsigned(addr_b(1 downto 0)));
    --q_b <= mem(conv_integer(addr_b_r));
    end if;
    when "11" =>
    when "10" =>
    when "01" =>
    when "00" =>
    when others =>
    q_b <= x"0000";
    end case;
    end if;
    end process;
    --generic map (
    -- Width_a => 64,
    -- width_b => 16,
    -- widthad_a => 7,
    -- widthad_b => 9
    --port map (
    -- clock0 => clka,
    -- clock1 => clkb,
    -- q_b => q_b
    Well the data width of R/W port must be the same the R/W enable signals are necessary.Even using "Shared variables", it's easy synthesized by Quartus II 8.0!
    Unfortuntly, I can not use"ramstyle " attribution with "no_rw_check" when using "Shared variables", because "ramstyle " ONLY for "signal" NOT for "variables" as follow code frage:
    signal mem : word_t;
    attribute ramstyle of mem : signal is "no_rw_check";
