16 years agoQuartus II 8.0 fail to infer following code to RAM:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity test_build is port ( clka : in std_logic; clkb : in std_logic; addr_a : in std_logic_vector(6 downto 0);--in natural range 0 to 127; data_a : in std_logic_vector(63 downto 0); addr_b : in std_logic_vector(8 downto 0 );--in natural range 0 to 511; q_b : out std_logic_vector(15 downto 0) ); end entity; architecture rtl of test_build is -- Build a 2-D array type for the RAM type word_t is array (2**9-1 downto 0) of std_logic_vector (15 downto 0); shared variable mem : word_t; signal addr_b_r : std_logic_vector(8 downto 0);--integer; begin process(clka) begin if rising_edge(clka) then --mem(conv_integer(addr_a)) := data_a; mem(conv_integer(addr_a) * 4+0) := data_a(15 downto 0); mem(conv_integer(addr_a) * 4+1) := data_a(31 downto 16); mem(conv_integer(addr_a) * 4+2) := data_a(47 downto 32); mem(conv_integer(addr_a) * 4+3) := data_a(63 downto 48); end if; end process; --rd_addr_t <= std_logic_vector(to_unsigned(addr_b, 9) ); process(clkb) begin if rising_edge(clkb) then addr_b_r <= addr_b; q_b <= mem(conv_integer(addr_b_r)); -- case (addr_b_r(1 downto 0)) is -- when "11" => -- q_b <= q_t(63 downto 48); -- when "10" => -- q_b <= q_t(47 downto 32); -- when "01" => -- q_b <= q_t(31 downto 16); -- when "00" => -- q_b <= q_t(15 downto 0); -- when others => -- q_b <= x"0000"; -- end case; end if; end process; --q_b <= mem(addr_b_r); --alt_ram : altsyncram --generic map ( -- Width_a => 64, -- width_b => 16, -- -- widthad_a => 7, -- widthad_b => 9 -- --) --port map ( -- -- clock0 => clka, -- clock1 => clkb, -- -- data_a => data_a, -- address_a => std_logic_vector(to_unsigned(addr_a, 7) ), -- -- address_b => std_logic_vector(to_unsigned(addr_b, 9) ), -- q_b => q_b -- --); end architecture rtl; As Tricky posted, it's not a bad idea to add muxes on the output, like the quoted part using "case" above. U need to asure the width of R/W ports is same, as well as the address.
