16 years agoQuartus II 8.0 DO infer following code to dual port RAM:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; --use ieee.numeric_std.all; entity test_build is generic ( DATA_WIDTH : natural := 64; ADDR_WIDTH : natural := 7 ); port ( clka : in std_logic; clkb : in std_logic; wren : in std_logic := '1'; addr_a : in std_logic_vector(ADDR_WIDTH-1 downto 0);--in natural range 0 to 127; data_a : in std_logic_vector(DATA_WIDTH-1 downto 0); rden : in std_logic := '1'; addr_b : in std_logic_vector(ADDR_WIDTH-1 downto 0 );--in natural range 0 to 511; q_b : out std_logic_vector(15 downto 0) ); end entity; architecture rtl of test_build is --type mem_t is array(0 to 511) of std_logic_vector(15 downto 0); -- Build a 2-D array type for the RAM type word_t is array (2**ADDR_WIDTH-1 downto 0) of std_logic_vector (DATA_WIDTH-1 downto 0); shared variable mem : word_t; --attribute ramstyle : string; --attribute ramstyle of mem : variable is "no_rw_check"; signal addr_b_r : std_logic_vector(ADDR_WIDTH-1 downto 0);--integer; signal q_t : std_logic_vector(DATA_WIDTH-1 downto 0); begin process(clka) begin if rising_edge(clka) then if(wren = '1') then mem(conv_integer(addr_a)) := data_a; -- mem(conv_integer(addr_a) * 4+0) := data_a(15 downto 0); -- mem(conv_integer(addr_a) * 4+1) := data_a(31 downto 16); -- mem(conv_integer(addr_a) * 4+2) := data_a(47 downto 32); -- mem(conv_integer(addr_a) * 4+3) := data_a(63 downto 48); end if; end if; end process; process(clkb) begin if rising_edge(clkb) then if(rden = '1') then addr_b_r <= addr_b; q_t <= mem(conv_integer(addr_b_r)); --q_b <= q_t(to_unsigned(addr_b(1 downto 0))); --q_b <= mem(conv_integer(addr_b_r)); end if; case (addr_b_r(1 downto 0)) is when "11" => q_b <= q_t(63 downto 48); when "10" => q_b <= q_t(47 downto 32); when "01" => q_b <= q_t(31 downto 16); when "00" => q_b <= q_t(15 downto 0); when others => q_b <= x"0000"; end case; end if; end process; --q_b <= mem(addr_b_r); --alt_ram : altsyncram --generic map ( -- Width_a => 64, -- width_b => 16, -- -- widthad_a => 7, -- widthad_b => 9 -- --) --port map ( -- -- clock0 => clka, -- clock1 => clkb, -- -- data_a => data_a, -- address_a => std_logic_vector(to_unsigned(addr_a, 7) ), -- -- address_b => std_logic_vector(to_unsigned(addr_b, 9) ), -- q_b => q_b -- --); end architecture rtl; Well the data width of R/W port must be the same the R/W enable signals are necessary.Even using "Shared variables", it's easy synthesized by Quartus II 8.0! Unfortuntly, I can not use"ramstyle " attribution with "no_rw_check" when using "Shared variables", because "ramstyle " ONLY for "signal" NOT for "variables" as follow code frage: signal mem : word_t; attribute ramstyle : string; attribute ramstyle of mem : signal is "no_rw_check";
