wa_itd's avatar
wa_itd
1 day ago
How to generate a netlist when the design includes encrypted sources
I would like to ship my design to a customer as an encrypted netlist, however I am unable to create the netlist after a successful run, because my design includes encrypted RTL (unable to change this).
I am running the following command (after running synthesis and P&R):
quartus_eda my_project --simulation --format=vhdl --tool=modelsim -c my_project_revision
I get the following error:
Error (18580): Cannot generate netlist output files because the design includes encrypted source files: "/path/to/encrypted/rtl/file.vhdp"
I see here that this was planned to be possible in "future" Quartus Prime updates, but I am using 26.1 and no such update has been made.
I have also attempted to run the following command, with the exact same result:
quartus_eda my_project --resynthesis --tool=modelsim
Any help would be appreciated; perhaps this is plainly impossible, or perhaps there is some work-around. Thank you!
1 Reply
  • ShengN_altera's avatar
    ShengN_altera
    Yes, you're right. That's plainly impossible. Based on internal engineering message, that error is expected behaviour and not a bug
