12 years ago
how to exclude code from simulation?
Hi all,
I would like to know if there is some way to exclude some line of VHDL code from the simulation but not from the synthesis !
I know tha the opposite is possible using synthesis translate_off.
I'm using Quartus 13.1 and Modelsim 10.
Thank you
1 Reply
    For code only visible to synthesis, you can use
    -- Synthesis-only
    -- Note: Quartus does not allow comments inside the read
    -- comments as HDL block.
    -- synthesis read_comments_as_HDL on
    **** Synthesis VHDL in comments, but no VHDL comments ****
    -- synthesis read_comments_as_HDL off
    For code only visible to simulation, you can use
    -- Simulation-only
    -- altera translate_off
    *** Simulation only code ***
    -- altera translate_on
    Cheers,
    Dave
