15 years ago
how to entrance & fanout internal logic cell
Hi everybody.
I use quartusII 9.1-sp1 and i develop on cyclonne-III board with serial flash memory epcs4 with 16mhz crystal.
But on my development board, when i add some signals-probes for debugging, or other signals, misteriouly :confused: the board not run correctly :confused:
My dev board is buggy randomly after modify shematic and reprogramming memory of FPGA. Modif is very simple i add/sub not-cell and probes.
I try lcell, but it fell like.
What can i do ?
Please, what is entrance and fanout of general logics-cells Into cycIII fpga or Altera cpld ?
Excuse my bad English.
Thank you.
    --- Quote Start ---
    Hi everybody.
    What can i do ?
    Thank you.
    --- Quote End ---
    I assume you add some connection to signal, which you would like to see on FPGA pins.
    Right ?
    Kind regards
    GPK
    Thank you for your reply.
    Is the unused pins can cause problems?
    Other question : If i make a symbol an i name some signals, for example "clk1" , is that this signal is seen as a global signal, ie that the other symbols take "clk1" into account ?
    --- Quote Start ---
    --- Quote End ---
    first of all you should look to the default setting of unused pins. You can found the setting looking under: Assignment -> Device -> Device and Pin options -> Unused pins
    Maybe your setting is " Output driven ground". This must be change to "Tri-stated input".
    When you add a new output did you assign the output to a certain pin ?
    Kind regards
    GPK
    Hi
    If i understand your reply : into the project settings > device and pin option > unused pin are setting to "as input tri stated with pull up resistor"
    Thank.
    --- Quote Start ---
    Hi
    Thank.
    --- Quote End ---
    yes, that should be the first step.
    Kind regards
    GPK
