15 years ago --- Quote Start --- Hi everybody. I use quartusII 9.1-sp1 and i develop on cyclonne-III board with serial flash memory epcs4 with 16mhz crystal. But on my development board, when i add some signals-probes for debugging, or other signals, misteriouly :confused: the board not run correctly :confused: My dev board is buggy randomly after modify shematic and reprogramming memory of FPGA. Modif is very simple i add/sub not-cell and probes. I try lcell, but it fell like. What can i do ? Please, what is entrance and fanout of general logics-cells Into cycIII fpga or Altera cpld ? Excuse my bad English. Thank you. --- Quote End --- Hi, I assume you add some connection to signal, which you would like to see on FPGA pins. Right ? Kind regards GPK
