15 years ago --- Quote Start --- Thank you for your reply. Is the unused pins can cause problems? --- Quote End --- Hi, first of all you should look to the default setting of unused pins. You can found the setting looking under: Assignment -> Device -> Device and Pin options -> Unused pins Maybe your setting is " Output driven ground". This must be change to "Tri-stated input". When you add a new output did you assign the output to a certain pin ? Kind regards GPK
