How to design a 1-out-of-3 clock multiplex
Hi!
I'd like to use a clock mux, e.g., altclkctrl, to select one of the 3 clocks generated by a PLL.
Unfortunately, I can't use altclkctrl because Stratix III's altclkctrl only provides 2 inputs. And, I can't cascade two altclkctrl because its input can only be clock pin or PLL's ouput clock.
I'm wondering if there is any way I can design a 1-out-of-3 clock multiplex?
Here is my configuration:
Terasic DE3 (Stratix III) + Quartus 13.1
You can use the Quartus assignment as Global Signal. Steps are as described in this kdb:
- JonWay_altera
Perhaps you can consider implementing it in the core logic.
You can refer to: https://courses.cs.washington.edu/courses/cse467/08au/labs/Resources/Recommended%20HDLCoding%20Styles.pdf
Page 56.
You will need to evaluate if this works for you.
- OCn
Hi JonWay,
Thanks for your reply and suggestion.
That Verilog code's function should be OK. And, how should I ensure that the output clock will use the global clock network, as that clock will drive a lot of circuit in our design?
- JonWay_altera
