OCn
5 years agoHow to design a 1-out-of-3 clock multiplex
Hi! I'd like to use a clock mux, e.g., altclkctrl, to select one of the 3 clocks generated by a PLL. Unfortunately, I can't use altclkctrl because Stratix III's altclkctrl only provides 2 inputs. ...
- 5 years ago
You can use the Quartus assignment as Global Signal. Steps are as described in this kdb:
JonWay_altera
5 years agoPerhaps you can consider implementing it in the core logic.
You can refer to: https://courses.cs.washington.edu/courses/cse467/08au/labs/Resources/Recommended%20HDLCoding%20Styles.pdf
Page 56.
You will need to evaluate if this works for you.
