How To Create A Custom Platform Designer Component That Uses Intel IP Components
- 3 years ago
It's probably possible, but not simple, since you need to add all the Intel IP files in the Component Editor. Instead, simply create a new .qsys with the design using IP from the PD IP Catalog. Then you can add it as a subsystem in any other Platform Designer system.
Thanks for the information.
My other option is to create an interface component in PD that I will manually wire up to the existing VHDL design.
It would be very useful if Intel documented preferred and supported design patterns for Quartus / PD rather than just giving information about all possible methods and leave it up to the users to figure out which ones aren't (easily) compatible with each other.
