14 years ago
How to configure the parameter during ModelSim simulation?
When I watch the wave during simulating in ModelSim, I always prefer to watch the inputs and outputs as unsigned or decimal number. But I also need to set the radix of all ports as "decimal" or "unsigned" each time when I simulate. I wonder how I can configure "unsigned" or "decimal" as default instead of setting it each time?
Thanks very much.
    --- Quote Start ---
    --- Quote End ---
    modelsim.ini has a default radix setting.
    However, I find its more useful to:
    1) Setup the waveform window how you like it, including signal radix and adding separators
    2) Save the waveform, eg., my_tb.do
    3) Then just load the waveform, i.e., do my_tb.do
    Cheers,
    Dave
    Thanks, Dave. This is actually create a macro file .do to do the same procedure. However, if I
    edit the files (e.g. HDL design files) which I used for simulation, I need recompile all the files, then the old .do files will not work, and I need to save a new one, right?
    --- Quote Start ---
    --- Quote End ---
    Yes, that's right.
    --- Quote Start ---
    However, if I edit the files (e.g. HDL design files) which I used for simulation, I need recompile all the files, then the old .do files will not work, and I need to save a new one, right?
    --- Quote End ---
    Only if you change the hierarchy of the design. But even then, you can think of the .do file as just another source file. When you edit the HDL and change the hierarchy, go and make the corresponding changes in the .do file.
    If you were using SignalTap II to probe the design, you'd also have to make the same change there, so its really not that much of an effort, or a change in mind-set.
    Cheers,
    Dave
    Thanks, Dave. I will try it. If I confront some problems, I will post here again.
