14 years ago --- Quote Start --- I wonder how I can configure "unsigned" or "decimal" as default instead of setting it each time? --- Quote End --- modelsim.ini has a default radix setting. However, I find its more useful to: 1) Setup the waveform window how you like it, including signal radix and adding separators 2) Save the waveform, eg., my_tb.do 3) Then just load the waveform, i.e., do my_tb.do Cheers, Dave
