14 years ago --- Quote Start --- create a macro file .do to do the same procedure. --- Quote End --- Yes, that's right. --- Quote Start --- However, if I edit the files (e.g. HDL design files) which I used for simulation, I need recompile all the files, then the old .do files will not work, and I need to save a new one, right? --- Quote End --- Only if you change the hierarchy of the design. But even then, you can think of the .do file as just another source file. When you edit the HDL and change the hierarchy, go and make the corresponding changes in the .do file. If you were using SignalTap II to probe the design, you'd also have to make the same change there, so its really not that much of an effort, or a change in mind-set. Cheers, Dave
