12 years ago
How should I write Verilog to describe DDR?
I have a design, which I need make the data is launched by double data rate (DDR). In this case, should I write the Verilog like this ? :
always @(posedge clk or negedge clk)
begin
output <= a;
end
Another approach I can think is I use PLL to create two clocks: clk1 and clk2. The period of clk2 is twice as clk1 while they have exactly same phase. Then, I use clk1 to launch data in SDR but output clk2 and data. Then the data with clk2 is DDR. But I don't think this is the right approach since this is actually still SDR.
Hope anyone has experience in this can give some advices.
Thanks very much.
    The always block isn't synthesizable.
    You'll use a altddio_out megafunction, it can't be inferred from HDL.
    Just to clarify, one can describe synthesizable DDR I/O in Verilog but, as FvM said, Quartus won't infer it and won't use the DDR I/O logic embedded in the I/O elements.
    So, you should use the altddio_out megafunction.
