Altera_ForumHonored Contributor12 years agoHow should I write Verilog to describe DDR? I have a design, which I need make the data is launched by double data rate (DDR). In this case, should I write the Verilog like this ? : always @(posedge clk or negedge clk) begin output <...Show More
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
