15 years ago
How do I prevent logic from being synthesized away?
I am using Quartus II 9.1 SP2. I have a VHDL design with thousands of electrical noise generators in it. The noise generators have only control inputs, no outputs. When I compile the model, all of the noise generators are synthesized away. This occurs even though I have assigned the VHDL KEEP attribute to latch outputs in the noise generators.
How do I prevent the noise generators from being synthesized away? There are so many generators that creating a dummy output from each of them, ORing the dummy outputs together, and running the OR output to a pin (or virtual pin) is not practical.
Thanks!
    try the online help at altera web site or quratus online help it will lead you to this :
    --- Quote Start ---
    preserve VHDL Synthesis Attribute
    There are two important limitations of the preserve synthesis attribute:
    It prevents a register from being inferred as a state machine.
    It does not preserve fanout-free registers. Use the noprune synthesis attribute to prevent Analysis & Synthesis from removing fanout-free registers.
    You cannot use this synthesis attribute for registers that have no fan-out.
    To use the preserve synthesis attribute, you must first declare the attribute in the local scope or import its declaration from the altera_syn_attributes package in the altera library. You can then use an attribute specification to associate the attribute with a signal or variable that infers a register in your design. For example, in the following code, the attribute declaration declares the preserve attribute as a boolean object in the local scope, and the attribute specification associates the preserve synthesis attribute with the signal reg1:
    signal reg1: stdlogic;
    attribute preserve: boolean;
    attribute preserve of reg1: signal is true;
    You can also set the preserve synthesis attribute on an entity or architecture, causing Analysis & Synthesis to preserves all registers in the entity or architecture, except registers that infer state machines.
    --- Quote End ---
