15 years agotry the online help at altera web site or quratus online help it will lead you to this :
--- Quote Start --- preserve VHDL Synthesis Attribute There are two important limitations of the preserve synthesis attribute: It prevents a register from being inferred as a state machine. It does not preserve fanout-free registers. Use the noprune synthesis attribute to prevent Analysis & Synthesis from removing fanout-free registers. You cannot use this synthesis attribute for registers that have no fan-out. To use the preserve synthesis attribute, you must first declare the attribute in the local scope or import its declaration from the altera_syn_attributes package in the altera library. You can then use an attribute specification to associate the attribute with a signal or variable that infers a register in your design. For example, in the following code, the attribute declaration declares the preserve attribute as a boolean object in the local scope, and the attribute specification associates the preserve synthesis attribute with the signal reg1: signal reg1: stdlogic; attribute preserve: boolean; attribute preserve of reg1: signal is true; You can also set the preserve synthesis attribute on an entity or architecture, causing Analysis & Synthesis to preserves all registers in the entity or architecture, except registers that infer state machines. --- Quote End ---
