How do I do line by line timing analysis in Quartus Prime Timing Analyzer?
- 2 years ago
I understood your intention however I don't think Quartus able to do that. In Quartus failing path only shown in STA report as it is, If you need the path b/w of the failing, (seem like a chain path of that node). you probably need to manually report timing (playing with from/to of intention node to manually compare it which I think bit tedious).
Let me know if there is any concern.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
