Pack_of_lone_wolves
2 years agoHow do I do line by line timing analysis in Quartus Prime Timing Analyzer?
I am familiar with the following timing analysis flow: Write an HDL design file (mostly .sv or .v). Simulate it. Integrate it into the project. Do synthesis, Fitter. Open timing analyzer -> Se...
- 2 years ago
I understood your intention however I don't think Quartus able to do that. In Quartus failing path only shown in STA report as it is, If you need the path b/w of the failing, (seem like a chain path of that node). you probably need to manually report timing (playing with from/to of intention node to manually compare it which I think bit tedious).
Let me know if there is any concern.
SyafieqS
2 years agoLet me know if you are able to cross probe node in rtl viewer.
This should be pretty straight forward.
- Pack_of_lone_wolves2 years ago
If I open the timing analyzer, I can select a node/path and then I can cross probe it in the RTL/Technology map viewer. But, I cannot select a node/path in RTL/Tech Map viewer, right click to see that path in timing analyzer.
