How can I use the default application to program Agilex 7 Series I dev kit using Quartus pro softwar
this is the dev kit configuration details.
<devkit><name>Agilex I-Series FPGA Development Kit</name><category>Development Kit</category><version>1.0</version><family>Agilex</family><device>AGI027RES</device><part>AGIB027R29A1E2VR0</part><vendor>Intel</vendor><description>The Intel® Agilex™ I-Series FPGA Development Kit delivers a complete prototyping and reference platform for designs needing PCI Express * (PCIe*) 5.0 (32 GT/s), Compute Express Link* (CXL) v1.1, or 400G Ethernet connectivity.</description><design>agilex_i_series_rdimm_ddr4</design></devkit>
- sstrell
What is the "default application"? What are you trying to do?
You can install the full Quartus software or just the Programmer.
- nashshah
get the dev kit running with hello world application and use the pof file for the board to initially program the board.
- nashshah
or I though I need a pof file first for the board or may be a bit file to generate a pof file however not sure which generic pof I need to program the board to start working with hello world application.
- nashsha
is there a sample sof or pof file available under Quartus dev kit examples directory?
I have synthesize the goldon_top project
however when I program the pof file generated form golden_top porject
using prime programmer pro edition and selecting the pof file by
clicking on AGIB027R31B agilex 7 device and changing to pof file it
errors out and says
Can not add flash memory programmer object file at top level'
I have a software background and it seems like I have to add more IP to top level
code and regenerate mu pof file. However not sure on where to start debugging and which IP
to add to get to the point where I can run my hellow world application.
- sstrell
You need a .sof file, not a .pof, to directly program the device over JTAG. You need to perform a full compilation of the Quartus project, not just synthesis, which generates the .sof.
- NazrulNaim_Intel
According to the previous comment from user 'sstrell'. The answer can be accepted, you will need a .sof file to directly program the device over JTAG. You need to perform a full compilation of the Quartus project, to generates the .sof file.
Hope that helps and do let me know if I can assist you further.
Nazrul Naim
- nashsha
No it does not help what I am asking is very specific to development kit DKSIAGi027FC what I am asking for is the following.
1) is there ready to test sof for this dev kit
2) is there Nios V/g sample example for this dev kit
3) is there a recommended sample application for this dev kit
4) rocket board does not have any this for this dev kit
5) is there a process to get things compile synthesis for this dev kit.
The generic answer does not help with trying to resolve issues with this dev kit. can you get back to me with details pointers to documentation on how to get the dev kit running with
a sample golden image location of SOF
a sample NIOSV/g sample
Bare metal hello world application
FreeRTOS hello world application.
- NazrulNaim_Intel
Nazrul Naim
