How can I use the default application to program Agilex 7 Series I dev kit using Quartus pro softwar
What is the "default application"? What are you trying to do?
You can install the full Quartus software or just the Programmer.
is there a sample sof or pof file available under Quartus dev kit examples directory?
I have synthesize the goldon_top project
however when I program the pof file generated form golden_top porject
using prime programmer pro edition and selecting the pof file by
clicking on AGIB027R31B agilex 7 device and changing to pof file it
errors out and says
Can not add flash memory programmer object file at top level'
I have a software background and it seems like I have to add more IP to top level
code and regenerate mu pof file. However not sure on where to start debugging and which IP
to add to get to the point where I can run my hellow world application.
