How can I disable or connect a module in a Qsys system
Hello Masters. How can I disable or connect a module in a Qsys system (or even in a subsystem) through a tcl script. The module is not custom. for example, in one case we connect the QSPI interface, and in the other CFI-flash. how can this be done using tcl, does anyone have any examples?
I want to change one parameter (type of circuit board) in tcl script and get the corresponding qsys system, either with qspi interface or with parallel CFI 👺 Help me please😔
1 Reply
- KennyT_altera
you can follow the steps below:
1) Open up platform designer
2) make some simple connection there
3) click files -> export system as Platform designer scripts .tcl
4) Open up this .tcl, you will notice all the properties and connection
5) Make use of this syntax to continue your development.
