VKap01
6 years agoHow can I disable or connect a module in a Qsys system
Hello Masters. How can I disable or connect a module in a Qsys system (or even in a subsystem) through a tcl script. The module is not custom. for example, in one case we connect the QSPI interface, ...
KennyT_altera
6 years agoyou can follow the steps below:
1) Open up platform designer
2) make some simple connection there
3) click files -> export system as Platform designer scripts .tcl
4) Open up this .tcl, you will notice all the properties and connection
5) Make use of this syntax to continue your development.
