16 years ago
Homemade TestBench attmept
Hola All,
I recently made a vhd file from scratch that tested some simple logic circuits successfully. All I have had as resources in this task is the tutorial files from ModelSim (counter.vhd, and tcounter.vhd), and a single text on vhdl (Circuit Design with VHDL by Peroni). Things were looking good until I attempted to make and test a frequency divider.
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs148.snc4/36780_10150214314760055_754135054_13023800_1551964_n.jpg
This frequency divider has one input (clk) and two outputs (out1, and out2). The code for this divider is below as well as the testbench I made for it. The problem is I get an undefined signal coming out of both my outputs. Any explanation as to why would be much appreciated.
Thanks for the assist,
Triston
****************************Freq Divider code*******************************
Library ieee;
Use ieee.std_logic_1164.all;
Entity Freq_Div_1 is
Generic(n : integer := 4);
Port(
clk : IN std_logic;
out1,out2 : buffer std_logic
End Freq_Div_1;
Architecture Div of Freq_Div_1 is
Signal count1 : Integer Range 0 to 7;
Begin
Process (clk)
Variable count2 : integer range 0 to 7;
Begin
if (clk'EVENT and clk='1') then
count1 <= count1 + 1;
count2 := count2 + 1;
if ( count1 = n) then
out1 <= not out1;
count1 <= 0;
end if;
if(count2 = 2) then
out2 <= not out2;
count2 := 0;
end if;
end if;
End Process;
End Div;
*************************** My TestBench Debacle *************************
Library ieee;
Entity tFreq_Div_1 is
Port(
End tFreq_Div_1;
Architecture testBench of tFreq_Div_1 is
-- ******** Component ******** ----->
Component Freq_Div_1
Port(
clk : in std_logic;
End Component Freq_Div_1;
--**** Test Signals ******* -------->
Signal clk : std_logic :='0';
Begin
dut:Freq_Div_1
Port MAP
clk => clk,
out1 => out1,
out2 => out2
clk_In : Process
Begin
wait for 10 ns; clk <= not clk;
End Process clk_In;
intialize : process
begin
wait for 1 ns; out1 <= '0';
wait for 1 ns; out2 <='0';
wait;
End process intialize;
End testBench;
