Just for completeness of this forum, my output waveform is below along with the testbench file, and the module under test. Thanks for the assist.
http://hphotos-snc3.fbcdn.net/hs047.snc3/13453_10150214833435055_754135054_13041362_2638503_n.jpg -------------------------------------- Module Code ------------------------------------------------>
Library ieee;
Use ieee.std_logic_1164.all;
Entity Freq_Div_1 is
Generic(n : integer := 4);
Port(
clk : IN std_logic :='0';
out1,out2 : out std_logic :='0'
End Freq_Div_1;
Architecture Div of Freq_Div_1 is
Signal count1 : Integer Range 0 to 7 :=1 ;
Signal count2b : Integer Range 0 to 7 :=1;
Signal out1_int : std_logic :='1';
Signal out2_int : std_logic :='1';
Begin
Process (clk)
Variable count2 : integer range 0 to 7 :=0;
Begin
if (clk'EVENT and clk='1') then
count1 <= count1 + 1;
count2 := count2 + 1;
count2b <= count2;
if ( count1 = n) then
out1_int <= not out1_int;
out1 <= out1_int;
count1 <= 1;
end if;
if(count2 = 2) then
out2_int <= not out2_int;
out2 <= out2_int;
count2 := 0;
end if;
end if;
End Process;
End Div;
----------------------------------- Test Bench Code ---------------------------------------------->
Library ieee;
Entity tFreq_Div_1 is
End tFreq_Div_1;
Architecture testBench of tFreq_Div_1 is
-- ******** Component ******** ----->
Component Freq_Div_1
Port(
clk : in std_logic;
out1,out2 : buffer std_logic
End Component Freq_Div_1;
--**** Test Signals ******* -------->
Signal clk : std_logic :='0';
Signal out1 : std_logic;
Signal out2 : std_logic;
Begin
dut:Freq_Div_1
Port MAP
clk => clk,
out1 => out1,
out2 => out2
clk_In : Process
Begin
wait for 10 ns; clk <= not clk;
End Process clk_In;
End testBench;
