13 years ago
help with counter
im trying to learn to create counter that starts counting based on the input that from the expansion after i compile it it seems an error occur and i dont know how to solve it. help me guys.. this error occured (Error (10500): VHDL syntax error at ledwithcounter.vhd(29) near text "then"; expecting ":=", or "<=") ....here i attach my program.. help me guys..
Library IEEE;
use ieee.std_logic_1164.all;
use ieee.numeric_unsigned.all;
entity GPIOwithLED is
port( GPIO_0 : in std_logic_vector(1 downto 0);
ld_enb : in std_logic;--parallel load enable,active high
clk : in std_logic;-- system clock
cnt_enb : in std_logic;--count enable, active high
rst_n : in std_logic;-- reset,active high
q : out std_logic_vector(1 downto 0));
end GPIOwithLED ;
architecture bufferwithGpio_arc of GPIOwithLED is
begin
process(GPIO_0)
begin
if (GPIO_0(0)='1') then q<=GPIO_0(1 downto 0);
else q<= "00";
end if;
end process;
counter:process(clk,rst_n) is
begin
if ( rst_n='0' ) then
count <=(others=>'0');
else(clk'event and Clk ='1')then
if (ld_enb='1')then
count<=GPIO_0;
elsif(cnt_enb ='1')then
count <=count+1;
end if;
end if;
end process counter;
-- assigment ouput
q <= count;
end bufferwithGpio_arc;
