library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity ledwithcounter is
port( GPIO_0 : in std_logic_vector(1 downto 0);
ld_enb : in std_logic;--parallel load enable,active high
clk : in std_logic;-- system clock
cnt_enb : in std_logic;--count enable, active high
rst_n : in std_logic;-- reset,active high
cnt_out : out std_logic_vector(1 downto 0);
q : out std_logic_vector(1 downto 0));
end ledwithcounter ;
architecture bufferwithGpio_arc of ledwithcounter is
begin
process(GPIO_0)
begin
if (GPIO_0(0)='1') then q<=GPIO_0(1 downto 0);
else q<= "00";
end if;
end process;
counter:process(clk,rst_n)
begin
if ( rst_n='0' ) then
count <=(others=>'0');
elsif(clk'event and Clk ='1')then
if (ld_enb='1')then
count<=GPIO_0;
elsif(cnt_enb ='1')then
count <=count+1;
end if;
end if;
end process counter;
-- assigment ouput
cnt_out <= count;
end bufferwithGpio_arc;
i have already done what u have said and now a problem oocurs.. Error (10482): VHDL error at ledwithcounter.vhd(31): object "count" is used but not declared.. how does i elminted this error..
