14 years agoHelp! Question about adder implementation!
I am try to build and test a very large adder, as my previous try have meet the quartus software constraints, my new way to do that is this: I write a basic logic for full adder, than a 4 bit adder consist 4FAs, and a large adder consist 500 4 bit adders. Here are the code: For FA: library ieee; use ieee.std_logic_1164.all; entity FA is port(a, b : in std_logic; cin : in std_logic; cout : out std_logic; sum : out std_logic); end entity FA; architecture df_FA of FA is begin cout <= (a AND b) OR (cin AND (a OR b)); sum <= a xor b xor cin; end architecture df_FA; For 4 bit adder: library ieee; use ieee.std_logic_1164.all; entity RCA is port( a, b : in std_logic_vector(3 downto 0); cout : out std_logic; cin : in std_logic; sum : out std_logic_vector(3 downto 0) ); end entity RCA; architecture struct_RCA of RCA is component FA is port( a, b : in std_logic; cin : in std_logic; cout : out std_logic; sum : out std_logic); end component; signal carry: std_logic_vector(3 downto 0); begin RippleCarryAdder: for i in 0 to 3 generate FAs: entity work.FA PORT MAP ( a=>a(i), b=>b(i), cin=>cin, cout=>carry(i), sum=>sum(i) ); End generate; cout<=carry(3); end architecture struct_RCA; For large adder: library IEEE; use IEEE.STD_LOGIC_1164.ALL; USE IEEE.numeric_std.ALL; entity CA is generic ( nblocks: integer := 500; vsize : integer := 2000 ); Port ( a, b : in STD_LOGIC_VECTOR(vsize-1 downto 0); sum : out std_logic_vector(vsize - 1 downto 0) ); end entity CA; architecture Behavioral of CA is signal carry : STD_LOGIC_VECTOR(nblocks downto 0); begin carry(0)<='0'; adders : for i in 1 to nblocks generate adder : entity work.RCA port map( cin => carry(i-1), a => a(4*i-1 downto 4*(i-1)), b => b(4*i-1 downto 4*(i-1)), sum => sum(4*i-1 downto 4*(i-1)), cout => carry(i) ); end generate; end architecture Behavioral; I haven't finish the clock and shift input part, and the code so far pass the compile and synthesis. However when I try do to compliation in quartus, a error "Error: Can't place 6000 pins with 2.5 V I/O standard because Fitter has only 342 such free pins available for general purpose I/O placement" poped up. and compliation stopped. And also in the summary, it said ony 29xx logic element have used, one of my contril signal(a,b or sum) have 500*4=2000bits long, three of them should have 6000 logic elements at least, why is that? Is that becasuse of I haven't finish the shift input part? Thank you all very much!
